Re: Troublshoot Yamaha LF150 trim and tilt problem
leak down on the 64E showa unit
up main check valve leaking
manual release valve loose or leaking
trim piston oring leaking
or the free piston orings in the tilt cylinder is leaking.
as it goes all the way up I would not suspect low fluid level.
