HELLO I HAVE A 1973 FORMULA THUNDERBIRD "233" 454 ENGINE AND TRS DRIVE.AT FIRST I HAD A PROBLEM I THOUGHT I COULD FIX EASY. MY DRIVE WOULD GO UP FINE BUT WOULD NEED HELP TO BE LOWERED "MY FOOT ON IT". SO I LOOKED AT THE PUMP AND NOTICED I HAD A SMALL LEAK COMING FROM A HOSE. SO I REPLACED ALL THE HOSES AND FILLED THE PUMP AGAIN. ALL HOSES TO AND FROM THE PUMP TO THE OUTDRIVE WHERE CHANGED . NOW I HAVE A BIGGER PROBLEM! MY PUMP IS PUMPING BUT MY RAMS ONLY GO IN ONE DIRECTION!! THEY ONLY GO UP BUT NOT DOWN. ONLY WHEN A CHANGE AROUND THE HOSES AT THE CYLINDERS DO THEY GO DOWN BUT THEN THEY WONT GO UP!THERE SEEMS TO BE NO RETURN OF THE FLUID AFTER NO MATTER HOW I CONNECT THE LINES. I WOULD GREATLY APPRECIATE SOME HELP ON THIS MATTER THANK YOU. WILLIE X2703@AOL.COM
