I’ll keep this brief. Long story short. I’m trying to help a boating friend best I can with a ridiculous machine he has almost completed. But such a machine is not what I’m used to at all. Far from it.
He has one of only 18 built tunnel hull boats. They were made in the late 70’s and one came to the U.K. for the boat show.
This one had a big block with twin turbos in it. I really think more for the show than for actual reliable use. I think this because it has an OMC800 drive on it, which is thought original. It has a seemingly crazy 1.77 ratio.
I don’t know much about these drives...but I do know that looking at it, even my V8 small block MPI would likely blow it up in 10 minutes.
now...it’s sat all this time since it’s 1978 boat show.
It is now being fitted with a big block performance engine with thousands spent on its components and internals. New turbos too and is expected to run upwards of 500hp at close to 6000 rpm. There is no way that drive is going to cope with it.
Mathematics at 100 mph, 1.77., 6000 rpm and say 10% slip would suggest a 35” prop at that. Silly stuff really.
anyway. I’ve advised that performance boats of that period with some power would likely run a TRS drive. Modern day would be perhaps a Bravo XR.
the budget is tight now after the engine.
question would be....what kind of power could an old rebuilt TRS take ?
what kind of power could a standard single prop bravo take at say 1.5 ratio ?
will he need an altogether more serious drive ?
ps I’ve also suggested that at 6000 rpm...he might be in the category of needing a rebuilt engine after every outing.
all opinions welcome. Picture below of actual boat in about 1980
