I'm trying to measure what I need for the pinion gear to be shimmed correctly. I'm using the correct tool that the book says 91-67441. The tool goes into the gear housing where the bearing carrier goes and you put a feeler gauge between the tool and the pinion gear and you have to get it at .025".
For anyone who has experience doing this here is my question. The book shows the tool directly under the pinion gear, however when i put the tool into the gear housing there is no way for it to be directly under the pinion gear as the tool can't go into the housing far enough. The tool is about an inch away from the gear. Is this normal? I guess i can still get a reading i'm just not sure how accurate that can be since the fealer gauge can have a chance to bend. Let me know please, thanks in advance......
