tootallofwa
- Joined
- Feb 20, 2010
- 177
I have an old automotive tach with settings for 4/6/8 cylinders. It has two leads, one for ground and one for the positive side of the coil. I have the positive side connected to one of my coil wires at the cut out switch and the other grounded. I have set it to 4 cyl and it works, kind of...
Now a 4 cyl 4 stroke coil, fires 4 times for every 4 strokes (2 revolutions.) My 2 cyl 2 stroke with 2 coils each firing 1 time for every 2 strokes (1 revolution.) So I figure the meter expects (and displays) 4 impulses for 2 revolutions (or 2 impulses for 1 revolution) and reading only one coil, my engine is delivering 1 impulse for 1 revolution.
That mean that it reads 1/2 as fast as my engine is turning. I think it would read correctly if I could incorporate the impulse of the other coil. (2 impulses for 1 revolution)
I think first, for it to work at all, there must be a diode to keep it from grounding the coil. Second if I connect it to both coils, that will connect the coils and not work at all. If each coil were isolated from the other with diodes, it would work.
Can anyone suggest an appropriate diode(s), I could use to connect the meter to both coils?
For those who don't know what a diode does... It works like a one way valve allowing power to flow one way and not the other. But I don't know how they are rated or what kind of voltage or current is on the point side of the coil. It can't be much if a 16 gauge wire can handle it.
