Re: Trying to determine proper dry/wet weight for Fisher Pontoon
Not sure how specific you need to be. I have a 2001 fisher 24 foot with 4 fishing chairs, a capacity of 12 passengers and a 125 mercury and it came with a Tracker bunk trailer with tandem wheels and surge brakes. I don't know what you intend to use for a tow vehicle, but I would advise you to go to a similar trailer. As long as you are buying a new trailer you might as well accommodate the probability of 2 footitis, and have a trailer that will handle the larger boat that is probably in your future. The surge brakes will help keep the boat from pushing your tow vehicle around. I am not sure what they consider a wet weight except for gas and a little equipment. You can figure gas at 8 pounds a gallon and my boat has about a 30 gallon tank. I believe the title for my boat listed 3100 pounds for weight if that helps you any. Remember you can never go wrong by going a little bigger rather than a little lighter especially in a trailer that you are wheeling down the road at 70 mph.
