Ok, <br />I have now gotten my boat back and she is running great. Just not as high in the RPM range as I used to have it. I Can get it up to about 4300rpms, but I used to have this thing tweaked out to 5000 RPMS. <br /> <br />I got it back from the shop, so they probably set everything to exactly stock is my guess, and I have Boyeson reeds in this thing. <br /> <br />I have a 17 pitch Hustler Prop, CMC PT-130 Jackplate, to replace the crappy T/T on the Force that always give you problems. I have the NGK BUHW plugs in the boat. <br /> <br />I think right now, the Air mixture screws are at 1.25 turns out, didn't have time witht he family on the boat to do any real tweaking this weekend. First time to get it on the water, since I got the carbs repaired. <br /> <br />She does run great now, but misses a little bit on the top end. I did put the larger jet in the Top carb also, changed it from a .094 to .1015 for my alititude. <br /> <br />It was running the 5k rpms in the past with the Smaller Jet in the Top Carb. Would this have had any effect on this? <br /> <br />The Tach is corect, it was specially ordered from Beade, for this exact engine. They had to make some changes to the Tach for it to work on this Engine. <br /> <br />Thanks, <br />Bryan
