Have a 1548 modified V tinny JON. Running a 1980 50hp Johnson on a jack plate 6" set back with a omc 11 1/4x21 SST prop. total weight 700lbs.
The best results is with ventilation plate aprox 3 3/4 above bottom, if I lower the motor it get a wicked porpoising when starting to trim it up from all the way in. I raise the motor (big mph gain) and the proposing will go away and I can trim it up a little over half way and then slipping, ventilation will result (not cavitation) water pressure still in the safe zone. It will start to over rev and need to lower the throttle.
I tried to redistribute the wait, no difference.
Will a bigger dia prop help, more cupping or more of a surface prop?
