Re: Trying to identify this plug in my boat..
Ok i made a second check and its the identical plug to mine, its also the same as on an older regal in my marina. it has internal threads, and as such is designed to fit on the opposite end of a hose from the pipe. The fitting that Regal uses for dock side water inlet is similar but a bit larger than this one, and is designed to have a pressure regulator in it.
wash down fittings tend to have external threads, for fitting the pipe (female) end of a water hose.
if its possible it would not be a bad idea to check to see, where the line on the inside of it goes to.
if you have your boat out of the water, with the drain plug out just in case it has been disconnected, just attach a water hose to it and introduce fresh water to it. if it comes out of your outdrive, its the flusher, if it comes out inside the bilge, then its disconnected. if u see nothing coming out check to see if your faucet work without your pump coming on, then its used for dock side water supply. (Note if this fitting is used for dock side water, then ensure a regulator is installed as there is the risk of city power being higher than the boat could take and blowing out a fitting, and flooding your boat. ) and once u have a water fill cap somewhere on your deck u could rule out this being the filler for your fresh water tank, which is very unlikely.
P
still No Fuss
