1983 Thundercraft Flamingo 470 merc 170hp it came with a I-R outdrive but i have replaced the I-R with a SE106 i think it's a alpha one i would have to dig out receipt to make sure but i'm sure it is. the prop size on the boat is what i'm trying to learn, i know the pitch is 21 because it's stamped on the prop but the diameter is not so this is my first time ever measuring the diameter i think i measured 13 3/4".
My first question: did i measure right for the 470 motor and outdrive with a 1.84 gear ratio
My second question: what other prop sizes can i use to improve performance, i'm not going to go top speed all the time i will be cruising more often then fast, probaly couple of times in a year i will be pulling a tube behind boat with 4-6 people on boat or just cruising with 4-6 in boat no tube. will the original size that came with boat is it good enough or upgrade?
