Trying to locate serial# johnson vr150
connersdadrules
Hello All,
I have a Johnson VR150 outboard. I've looked all over but can't find the serial, maybe its hidden. Any help would be appericiated.
thanks
John
JB
Re: Trying to locate serial# johnson vr150
If you want to find out the year model it is the model number you need, not the serial number. It should be on a small plate riveted to the transom mount.
Failing that you might find it on a welch plug on top of the power head.
Good luck. :)
tashasdaddy
connersdadrules
Re: Trying to locate serial# johnson vro150
Hello,
Its a vro 150. I found a plug on the block with G3074626 on it but I thought that was to short.. Here is a pic of where it is . If thats it, how do you tell what year and model??
thanks
john
tashasdaddy
that is a serial number, no published, dealers are the only ones with access, call at dealer.
