lookingforluck
- Joined
- Mar 6, 2007
- 47
Does it hurt to run a 150 mariner 1993 without the tstats and also how do you back flush the cooling system? May have gotten some sand in there.
That sums it up nicely.remove tha stat and wash backwards, they put the stat in there for a reason. the engine is designed to run at a certain temperture. running with out the stat, the engine runs cold, effecting performance, adding to carbon build up, and other problems. get a stat. if you have a lot of sand, replace the impeller,
