tstats???
ripper1
were are the tstats located or if there are any om my 69 85hp evinrude ...noticed no water comming out of the 2 holes on the back going to change the impellor...just wanted to know were the tstats are located...is there a water pump on this motor as well??? thanks for all those who help :eek:
one more cast
Re: tstats???
Ripper, The impeller is part of the water pump.go up to "Helpful Links" on the top of this page and click on manuals. Place an order and you will be on your way.
Walker
Re: tstats???
Look at the back of your powerhead. Down at the bottom you will see 2 short 5/8" rubber hoses, one coming from each head going down to a block in the center. That block contains the T-stats.
