Re: Ttrouble Mating Lower Unit: '78 Type 1 Merc
Folks, having just started on this forum on Saturday, am blown-away -- and VERY appreciative -- of all these inputs. Hugely helpful:<br /><br />+ Ziggy / All: my apologies about my foul-up on my Item 1: I meant "shift handle", not steering wheel. (I was also lubeing the steering stuff -- hence my brainfade..) My son was at helm, and he pushed it forward (out of neutral) at least ~4 or 5 inches to the initial detent -- but no movement of the shift shaft (that is -- the upper most shaft, that has a little receiver that holds the top of the shaft mounted in Upper.) <br />Re where the shift shafts meet: I was able to see where they meet pretty clearly -- under the gimbal housing (I think that's it's name), when the upper unit was tilted full-up. <br />Will re-read your input several times: seems you might be saying there is ANOTHER shift shaft coupling up further in the Gimbal or Bell housing.) <br />Re the seal debris I found: I / the drive shaft probably somehow wrecked that Upper seal during attempts to mate. Re the health of the lower drive shaft: I remember a TINY ring scoring / scratch below the O-ring groove -- are you saying the drive shaft is kaput???? <br /><br />+ Tommays & Babylon: I'm going with your suggestion re building a stand. Any quickie drawings avail on-line?? <br />Tommays: so the gear oil is kept ABOVE that driveshaft coupling, and also down where the forward/reverse gearing is, correct?? (Would seem like such a better design to bath it all in lube, but then there would be problems with oil leaks where the Upper/Lower mate, correct?)<br /><br />To all: much thanks! Another buddy says best to take off the Upper to check for proper lubing and alignment up there, so.....work lies ahead. Will research the manuals, re Upper.
