Tub rinsing motor
Matthew A.
I recently began to use a rubber made 100 gal tub to rinse the motor after a day on the water instead of using the muffs. I did so for two reasons. One to save water and to make rinsing the motor a much quieter event.
However, the last two trips out I noticed a drop in water pressure at higher speeds. What once read 10 to 12 psi now reads 7 or 8 psi. at 3000 rpms and above. The psi will come up to around 10 or 12 psi for a few moments when going from a low rpm of below 2000 and quickly throttling upwards to 4000 rpm or higher. However, the psi then begins to settle to the 7 or 8 psi and remains painted there until you lower the rpms again. The motor is not running any warmer then it normally does, even after running at high speeds or low speeds for long periods of time. Flow out the pee holes is excellent.
I am wondering if perhaps the impeller is getting damaged from the small amount of residual oil and fuel that gets mixed with the water. Or, could the extra lubrication due to the very slight fuel oil mix in the water be doing something to lessen flow restriction or [for all you pipe fitters out there] lessening the "friction loss" thru the block via smoother action of the pressure bypass components, less restrictive corrosion perhaps or....?
The impeller and seals have around 100 to 150 hours of use. However, we have only rinsed the motor using the tub method 3 times. Each time rinsing the motor for 20 minutes or so. Water temp of water in tub after rinsing goes from 65 degrees at the start and warms to 80 to 85 degrees when rinse in complete.
Frank Acampora
Re: Tub rinsing motor
Every medical student gets every disease he studies. Moral: Stop overanalysing it!
That's the trouble with a pressure gauge: You read too much into it. If the engine is cooling properly and you have adequate flow out the indicator, what is the worry? We are not dealing with rocket science here.
Yeah, you may have an impeller with slightly degraded performance, but with you keeping an eye on it, it is highly unlikely that you will be stuck out on the water. Now, if the pressure keeps steadily dropping with each use or drops to 2 or less---it's telling you that you better do something--soon.
Matthew A.
Heya Frank,
Since I do not know if the impeller is made of Buna or Nitril or some form of other rubber material, I guess the most efficient and for sure way to know whether or not fuel/oil mix maybe harming to the impeller is to set aside 15 minutes to drop the LU and take a look at the impeller. Good time to replace the LU oil as well.
Hmmmm.....tuna time should hopefully start any week! Here fishy fishy fishy....come on nice fishies...yes, lots of nice lil fishies...heh heh heh...get in the boat now...
