Please share any tube cleaning tricks you may have.
We just pulled our 24' Landau off the water where it's kept floating in a slip; plan on doing some annual maintenance and cleaning during the next couple of weeks before taking back to the slip.
I've already picked up a gallon of Napa Aluminum Brightener to use but what is the best way to clean thru the accumulated crud that has built up on the tubes. We cruised thru a car wash and hit the tubes briefly while they were still wet to avoid the crud from drying up - overall they're not too bad but we do have a some build-up and a water line that's a bit rough.
Best initial cleaner before using the Napa Aluminum Brightener?
Any good drill attachment for getting the rough stuff without too much wear to the aluminum?
Recommendations for using the Napa Brightener? Dilute and use a hand or pump sprayer?
Thanks,
Steve
Thanks,
Steve
