We have a '97 24' Landau pontoon that we're moving to a different marina.
I had been on a lift but will be in the water at the new marina as they do not offer rental lifts and a purchase is not an option right now.
Wet slip is an inland lake in north Texas. Joe Pool Lake in the DFW area.
We do have a trailer and pulling the boat annually for cleaning is not a big deal.
We're not overly concerned about 'shiny' show boat tubes...mainly concerned about function - keeping algae away in order to maintain performance & fuel economy.
Questions:
- Should we apply anti-fouling bottom paint? (sure to use paint for aluminum).
- The tube plugs have never been pulled, they are aluminum hex head with pipe dope sealant; wise to pull to inspect for any water? (On one hand I think it's prudent but on the other I sometimes thinks if it's not broken & don't want to run the risk of damage).
- The boat does not list to either side and seems to float fine from my limited experience.
Assuming it's wise to pull the plugs for inspection; how best given aluminum plugs w/ pipe dope?
- Carefully heat with mild torch or heat gun to loosen pipe dope?
- Careful steady torque with a half-inch drive rachet or is an impact gun better?
Questions:
