I pulled my boat out to get it cleaned up and ready for summer and while giving it a good bath, I heard a noise which sounded like a small air leak in one of my tires...After several minutes of crawling around under the boat, I realized the noise was coming from the plugs in top of the tubes. When I loosened the plug, the noise stopped. I know these plugs are for leak testing at the factory. The plugs in my tubes are plastic. Would it create any problems if I drilled a small hole it the center of these plugs to equalize the pressure in the tubes. Would there be a possibility over time for water to enter the tubes?
Thanks
KEEP IT FUN...KEEP IT SAFE!
Thanks
