Tubing skiing rigging question
atomb
I have a 3.0 bayliner capri i want to use for tubing / skiing. I picked up an eyelet for towing from the boat shop and plan to install it I have to other rings on either side of the outdrive. Can anyone give me some tips on how to rig up maybe some links to a few pics of different ways ..thanks for any info.
kyle f
Re: Tubing skiing rigging question
One thing I am thinking here, is backing plate! Use a big piece of wood or some sheet metal to help spead the load out or gel coat cracking could be a major issue.
Also, run you drill for the holes in reverse, it prevents cracking as well.
kenmyfam
Can you not use a harness with the other 2 ???
atomb
i havent bought anything but the ringlet i need some towing 101 info
