Andrea Gail
- Joined
- May 1, 2004
- 11
My engine is a Johnson from 1985 <br />Modelnumber: J20BEL0NB <br />Serialnumber: B007701<br />Two cylinder <br /><br />20HP spark advance 34 degress (and it says 1978?)<br />Manual start<br /><br />A dealer told me that the only things that were different between 20 hp to 35 hp were the carburator.<br />I have changed the carburator, I noticed a nylon limiter at the orginial carburator.<br /><br />BUT, there was no difference in perfomance at all, nothing.<br />The engine ran good at idle but at high speed it was weak, so I pulled out the choke and then it started to give more power and sounded better.<br />This can´t be right?<br /><br />I know that the manifold is really small on this engine, compared to the carburator diameter.<br />I have a identical engine from 1976, this engine has a manifold that is as wide as the carburator.<br />It seems more logical, because a small manifold becomes a limiter?<br />Isn´t that so
?<br /><br />//Jens
