Tune up kit for 1964 M0del# 28402M
csisommout
Hi, planing to replce all electrical components under the flywheel.
Just wonder if the tune up kits include coil,condensor, points.. etc
That i need to replace.
I have Seloc service manual does not cover pacific model. Thank you.
steelespike
Re: Tune up kit for 1964 M0del# 28402M
Kit would be points and condensers.Coils would be extra.
No need to replace the coils if they appear undamaged.
Bad coils are usually discolored and cracked.
R.Johnson
Crack's are not alway's a true indication of coil condition. They can have a internal break, or short that only a power test can detect. Those crack's you see on early coil's are the result of early epoxy curing. As these early coating's dried, they also shrunk, thus cracked. I have seen on this board, people see'ing crack's on a coil surface, and replacing them all. They do that because someone said they should. How many on this board have a Steven's coil tester, or access to one?
csisommout
The reason, I want to replace tune up kit, because when I cheaked the spark
I saw only spark on top cylinder, not on the bottom one. I could had done it
wrong though. I pull plug out and attached a boot on it then pressed against the block, while having other person turning a key.
Is that right way to do it? Thank you.
F_R
Well that is a good way to fool yourself into thinking it is ok if you see sparks. Otherwise it is meaningless. You should rig up a 1/4" spark gap and see if it will jump that. However, you said there was no spark at all on one cylinder--there is no doubt on that one. Something is wrong.
