tune up
Jcris
I've got a !996 4.3 l LX Mercruiser. I've noticed it seemed a bit sluggish when starting so after inspection I replaced plugs and the distributor rotor and cap. The old ones looked worn so I figured I might as well start fresh with some new ignition components. After this work I found the timing was a bit advanced as well as the idle rpm. So I adjusted the timing to 8 degrees BTDC and the idle to 650 per manufacturer spec. I did these adjustments after the motor was up to normal operating temp. Specifically 160-170 water temp. Took it out this morning and the sluggish starting has not gone away and now it seems to run on a bit after I shut it down. It seems I've gone the wrong direction. This is a 2 barrel carb and it has been quite awhile since I've wrenched on anything carbureted. The starting battery is older (2009) but holds a decent charge (12.8 vdc). I'd like some advise on where to go from here.
Thanks,
Jcris
Your 96 should probably have the TB-V ignition, and 10 BTDC would be correct if that is what you have. If this is the case did you ground the Purple/White wire when setting the timing?
Jcris
Thanks AllDodge,
I'm going to recheck the timing this afternoon
Ayuh,..... Don't let it do that, turn the key back On,....
The last studder/ shutter ya hear from a dieselin' gas motor is it runnin', Backwards,....
It'll suck in water, 'n hydro-lock,...
I didn't see fuel filters mentioned in yer tune-up,....
If the timin' in dead-on, check to see if the carb is dribblin' gas down the venturi,.... as in leakin',...
Heat also plays a role in dieselin',.... let it idle a minute or so, 'n see if that helps,...
Jcris
Hey all dodge,
Turns out this motor does have the TB 5 ignition. I retimed to 10 BTDC at 650 rpm idle, purple/white grounded.
What can I say, learning curve still exists for this old man
Jcris
