turbocharging
letsgo19
Does anyone know who makes a turbocharger for a merc 305 220hp?Or IF anyone does?:confused:
proshadetree
Re: turbocharging
Never seen it on a boat.What you going to do with the pipes?Open engine compartment?Needs to be or be large to get rid of extra heat.Im sure there is a way but do you want to go through all the extra stuff to get it working.Injection needs to be programed carbed needs to be jetted.Turbos are great on cars but Ill live without one on my boat.
Knightgang
Re: turbocharging
Agreed. remember, turbo charges use exhaust to drive them... You might look into superchargers instead... Not sure how that would work out, but it might be worth looking into...
270win
Re: turbocharging
I just re-read the question...
I'm sure a company like turbonetics could help you.
I wonder if a ProCharger might not be a better alternative...belt driven, separate oil reservoir, less heat buildup. Just a thought.
180shabah
Re: turbocharging
Turbocharging is typically not the best solution on a boat.
What boat do you have, what are your current performance numbers, and what are you trying to accomplish?
270win
Re: turbocharging
Actually turbos are perfect for long periods of constant rpm operation. But low end power in a gasoline engine will be lacking. From 3,000 rpm to redline it would be pretty impressive.
If you do boost it, torque will go way up, better make sure your drive is up to it.
Also, you need to make sure your compression is low enough to boost...unless you plan to go with very little boost or inject methanol.
joey maneri
Re: turbocharging
I just looked at some prises from pro charger, I think it would be cheaper to put a diferent engine in the boat, maybe a 320hp 350? plus alot less problems. and then you would have a fresh new motor.
270win
Re: turbocharging
I agree with that! Same with a turbo from Turbonetics or Air Research. By the time you do all of the work and purchase the parts it would be much less expensive to just repower and stay N/A...(naturally aspirated)
180shabah
Re: turbocharging
Again I cast my vote for staying NA. The water cooled exhaust (including the turbo, which will cut its efficiency)is a very expensive hurdle to overcome.
We still don't know what the OP has, or what he wants to do with it?
wca_tim
Re: turbocharging
there are some gale banks twin turbo units running around... as well as some other custom set-ups. I believe the banks set ups tie in between the manifolds and risers on a merc exahaust (I' pretty sure they were a "bolt on" upgrade and i ran across a set-up for sale not long ago for a couple thousand dollars), but I think turbos are tough to get the mapping right on for a typical "backyard hack" for fuel injection or a pull through carb... although this is more of a guess than first hand experience. I've recently read and heard some very interesting stories about using blow through (for marine put the carb in a box just like a procharger) set-ups...
and the new rage on high end performance engines is running turbochargers... but they're not for the light of pocket book... over a thousand horsepower out of a 540... for $60k
http://www.shopecm.com/Scripts/prodView.asp?idproduct=10306
if i were you I would go with a normally aspirated performance built engine... you'll spend no more and it'll just be easier - lots more people know how to do that right...
just my two cents...
mylesm260
Re: turbocharging
He was referring to theory vs practice.
In theory, turbocharging a boat is a fantastic idea, like you said more power, more torque, steady rpms, a little bit lagy of a hole-shot but once the boost kicks in you're laughing.
in practice, the exhaust safety and corrosion resistance makes it not worth while. you would be MUCH better off going supercharged.
No off the shelf turbo charger is going to have the jacketed exhaust housing and the corrosion resistance necessary to work safely or for very long in a boat.
Not to mention, most marine motors are far to primitive to be adaptable to handle the necessary fuel and ignition curve of a turbo charger.
To do it properly, you would need:
A marine (water proof) programmable EFI controller
Custom water jacketed manifolds
custom turbocharger turbine housings. (don't exist to my knowledge)
Custom compressor wheels, made from stainless
A water to air intercooler
The modifications necessary would also decrease the efficiency of the whole systems. Turbochargers work well because they draw heat from the exhaust. If you're manifolds and turbine housing are water cooled to the point where they're not a fire hazard, you're exhaust will be colder and you're turbocharger will less efficient and more laggy.
madgadget
Re: turbocharging
And if you wanted to be really posh try with a VNT turbo... :)
Re: turbocharging
Ayuh,.... I've got most of the makin's for a twin draw-thru turbo 400 Chevy berkley jet boat...
Just no time...
But,...
The OP is startin' with a 305,....
Turbos aren't the 1st step in Hot Roddin' his boat......
