I?m new here and from what I?ve read this a cool site, I?m sure you can help me and in time I think I will be able to help others.
I bought a 1994 Fling with turbojet 115. It didn?t run but everything looked good and the price was about a third of the going price in this area. I put a stator in it and now it runs. My issue is no water flow through the engine. I removed plug, spring, and check ball, only to find they are clean and move freely. I tried to back flow water from the strainer to the jet pump housing and I get no flow. Is the water passage with the pressure relief ball, connected to the hose going to the strainer? With the spring and ball removed could in get garden hose water to go through the pump housing and then into the motor? I?m thinking the hose from pump to strainer may be plugged. I looked at most of the post here about turbojet and haven?t found any that talk of this issue. I will thank who ever now and again if I can get this cooling problem solved.
Thank You
Jim
Thank You
Jim
