turn singals
mav1973
i have a 93 ranger bought new lights for trailer and wire everything works when i turn the turn signals on without the break they flash very fast i put the break on they work fine ive bought the hook up that goes right to the light hook up to the truck i grounded thatto the frame of car ground trailer lights to trailer can anyone help thanks soo much
Ralph 123
Re: turn singals
Sound like a ground problem. Try Bondo's fool proof method for ruling it out:<br /><br />Take a set of Booster Cables, Hook one ends to your truck frame.... Hook the other ends to your Trailer Frame.... Wiggle,+ Shake them to be Sure you've Got Bare Metal......<br />NOW You Have a Good Ground......<br /><br />If that fixes your problem you know the ground on the trailer or truck is not good enough.
mav1973
Re: turn singals
WELL i tryed that still nothing haszards work fine could be the fuse not strong enough everything works unhooked on the car
IA rookie
Re: turn singals
You may need to buy a different "flasher" relay.<br />On some vehicles the turn signal and emergency flasher relays have the same style sockets.<br />If so, you can switch the relays. If this solves the problem, just buy another emergency flasher relay to use for the turning signals.
bubbakat
Re: turn singals
Like rooki said the flasher is not heavy enough
mav1973
Re: turn singals
hey thanks again im going to the auto store going to try bigger fuse will post again if need be have a safe weekend
roscoe
Re: turn singals
Don't put a bigger fuse in, that will allow the circuit to be overloaded. If the fuse was too small, it would have blown due to too much current going thru it.<br /><br />You need a heavy duty flasher relay. They are only $2. Unplug the old one, plug in the new one. Done.
