Hydro Mark
- Joined
- Mar 30, 2013
- 56
I just received my new Turning Point Hustler prop from Iboats. One of the features they tout is that the exhaust ports in the prop are opened up for increased horsepower and that was one reason I chose TP. My 1968 Mercury 1250 125hp 2-stroke came stock with an open exhaust (no exhaust tube). So I wanted to make sure I didn't compromise that design by choking it at the prop.
I was surprised that the TP prop had thick, straight, blunt hub ribs the whole length and fairly narrow exhaust ports. My Mercury prop has helical ribs and they are tapered on the leading and trailing edges as well as not going the whole length of the hub. The ports are larger as well. The hub center is also tapered.
Should I not test it and return it for a mercury? Or am I placing too much importance on it?
It seems to me that if TP is touting it, it must be an issue, but the mercury prop clearly flows better by design.
Thanks,
Mark
Thanks,
Mark
