To start of I do have a mercruiser manual. But im flailing/failing. My first question is can you guys have a look at how i have my spark wires going to the cylinders and tell me if im correct. I seem to have spark and fuel so i feel like either my timing is messed ..
My valve adjusting has not been too succesful and i have been following the book but im a human monkey so i guess i probably did something in err. heres a pic of the wires and a pic of how i wired her up.
Second question --Valve adjusting as per the instructions i get her to tdc and specifically tighten down the ex and Intake on the first and continue on with spoecific valves... then it says rote crank one full revolution which seeems like it gets it to the exact same spot tdc on number one but it wants me to be on TDC #4 --BTW this is a pain because i have to jump the starter solenoid i\ -i have not enough belt tension to crank the alternator nut and make the crank rotate..the alternator bracket is maxed out..so hence im using the starter solenoid to do this. rewind for a minute as per reassemblly the manuall says torque valves to 20 lbs and no adjustment needed after that but I got no valve movemnet at all when i did this then i wen to valve adjustment of engine not running and yes i got movement but seemed a bit tight to me. I had a buddy mechanic come over and set the distributor yesterday and said that all sounded find in terms of not having compression at the time ... since then i have switched the spark wires too alternate cylinders .
I hopoe you guys can fooloow if not ill try to answer any questions you may have to move forward .. thanks for any suggestions Im pretty frustrated its been a long journetyy with this motor. I feel like im really close
I have the camera handy so if there is something you want to see please just ask... no naked pic requests I pretty ugly:redface:
