Re: Twin 230 merc i/o throttle sync
Yea you should be able to. When you are at idle it could be both cables have hit the stop and one still has a little flex in it. When you open the one with no flex the carb opens right away. The other will be a little late because you are taking the flex out. Would try closing both throttles, take the linkage loose from both engines, should just be taking the cotter pin and nut off the linkage bolt and seeing if the bolt on the carb matches the hole on the linkage. Mine has an all thread at the end of the throttle cables at the carb end where adjustments can be made. Also, if you can, check to see that the linkages on both throttle levers are in the same place.
