Twin 5.0L MPI's - Different Fuel Flow Rates
pwrplay
Hi guys,
I have a Four Winns Vista 318 with twin 5.0L MPI's and when both engines are running the extact same RPM the port engine is consuming about 1.5 to 2 gallons per hour more then the starboard engine when running at 3500 RPM's. It doesn;t matter what speed, the port engine is always sucking more gas. Also, the the port engine's oil pressure is higher then the starboard engine.
Any ideas why? is there a problem with the port engine?
achris
More fish than mountain goat
Re: Twin 5.0L MPI's - Different Fuel Flow Rates
Swap the sensors across and see if the problem is a sensor calibration.
