I am running twin 1977 Evinrude 70HP motors on my whaler. Great motors for 30 years, had one top end rebuilt 7 years ago including carbs, the other, just the carbs. Like I?ve said, they ran great, now this.
I run them for a while at 3500 (like 5 minutes) then lefty bogs, coughs, and stumbles. I thought it was the fuel pump so I switched our the one from the good engine, and put it on the bad one and it did not help. Put everything back as it was and now both have the same problem.
1.) Compression is ok 120-122 on both engines.
2.) Fuel pump is ok as I bypassed it and ran a new tank with new fuel a new hose and bulb directly to the carbs with a buddy pumping it while we ran the engine up to 4k in the slip, then she bogs, and stumbles.
3.) new coils
4.) new spark plugs, all gapped correctly, all with spark
5.) new fuel lines
BTW, the only way to get it to run well again is to pull the carbs, clean them out with carb cleaner and then put them back on, then they run for a while and bog and stumble.
Questions:
I?ve searched on the forum and it seems like it's the carbs but not sure. I hate pulling stuff apart as I fear I might be causing more problems. Any help would be appreciated.
Thanks guys.
3.) new coils
5.) new fuel lines
Questions:
- Should I just rebuild each carb myself?
- Is it that hard to do?
- How do I sync them( or do I have to ) afterwards?
- Should I replace the floats as well?
- Could it be a power pack issue?
Thanks guys.
