Twin Bravo3
shanz_2008
Hi guys
Ineed an advise ! I am preparing my boat for the season Sea Ray 290DA year 2007 twin 4.3MPI with Bravo3 drive.
I noticed that if you look at the drives from the back they are not straight but a little bit open from the back.
When I measured them from center of the gimbal ring it is 33" and from the center of the lower unit drive it is 34".
Are they as it should be or they have to be both the same 33"
Thanks
Clive
tpenfield
They should be straight, so the same measurement (33" in your case) for both. You probably need to adjust the tie rod.
