Twin Screws or One Big One
valleydawg
Starting to narrow it down. One boat has twin Johnson 150 that are 2 stroke (400 hrs) one boat has a 4 stoke 225 Yamaha (600 hrs) which would one pick. Both seem to be in good shape. Thanks for the help.
kenmyfam
Re: Twin Screws or One Big One
Same boat ???? what is it ???? and what is the HP rating of the boats ???
commander315
For me it would depend on the kind of boat, its year, and the Max H.P. Rating
valleydawg
24 ft Proline CC w/ Yamaha and 24 ft Hydra-Sport CC for the 2 Johnsons.
Philster
Depends on how you use it.
Deep/offshore and with increased risk from other longer/farther journeys, then that justifies having twins.
Near-shore and in-shore fishing, etc, then go with a single.
Mike Robinson
One thing to consider is that the single engine should be more economical on fuel.
commander315
very true, i agree. Yamahas are great engines, soo..
dingbat
225 HP isn't enough ponies for the Pro-line. The Hydra could use more ponies but will suffice.
ovrrdrive
Another thing to consider, the boat with twin 150's probably won't get up on just one if you should have a problem. If you were really far out you could basically troll in on one if you had the gas, but you'd be out there all day anyway. If I were rigging a new boat I'd go with the one bigger motor and a big *** radio and a membership to Seatow, but on a used boat I'd get which ever combination was in better shape that I felt was more reliable.
elkhunter338
twins, a 150 will push a 24 foot boat ok and will get you back to dock in a reasonable amount of time.
