Re: twin turbos on a 350 - input?
Are the turbos made for boating use, or automotive? If the exhaust doesn't have to be cooled, like on most inboards, it should work. As far as automotive, I think the expected power increase for one good turbo is about 33 percent, but due to law of diminishing marginal return, you might expect 50 from 2. Twin turbos are an effective setup done right, but you might want to consider recamming, port and polish, and bigger carb with one turbo. You might save some money, and get more power. As with anything though, power and reliability don't go well together. Good luck, and definately check out the carb, cam, 1 turbo combo to see what's up. I think it will do better.
