I have just purchased a large used RIB with existing props that we sea trialed a couple of weeks ago. I am now in need of selecting other props and would like to ask what choices may make sense for my application. I have read a bunch about props so I likely know just enough information to get myself in trouble here but I will give it a shot anyway. My goal is to select reasonably priced SS props for all around use to include cruising, and towing skiers with 2-6 people on board. At sea trial the engines pinned the tachs quite easily with a 2-3 foot chop, strong wind, in salt water and 5 people on board (adults). The boat held plane easily at 30mph @ 3,800 rpm?s as well as at lower speeds
Boat is a 2010 Nautica RIB , Catamaran (shallow hulls), 23' long, 8" 6" beam (tube to tube), total weight rigged to is 3,250#'s, (hull 1,790, engines 960, fuel etc 500). The hulls are 24? apart at the bow and shallow along the length, they are asymmetric.
Current props are ?stock? Yamaha black painted SS, 3 blade 19? pitch.
Motors ? Twin 2009 Yamaha F150 4 stroke, 2.00 lower, counter rotating, in good condition, tachs are Yamaha digital. WOT range is 5,000 - 6,000.
Mounting - Mounted with jack plates and adjustable over keel range at 2nd hole static. There are no doel fins, trim tabs, or other 'things' back there.
What are my options in type and pitch of prop and what else can I do to help determine this? I have had good success with Solas props recommended here but they have many options on the site. Can I begin to select reasonable replacements at this time - and if not what do I test again when the boat is back in my hands?
Thank you
Thank you
