Re: Twins Vs Single
Thanks for the reply Ancient One ;~) I feel a little stupid because I have now seen other threads with this question. That being said, I feel that each person's 'needs' and 'wants' vary some. In my case, I live on the NW coast and will once in a while go offshore, but not far. Being broken 1 mile out or 5 seems a moot point. I plan to 'see the country' and cruise where I can. (retired) This could include some larger bodies of water and large rivers. So security will be of importance. But today's motors are pretty reliable, so...??? Second is that I REALLY want that vintage look (with modern power of course). However, I don't want to make the boat stern heavy with too little power by doing twins. So then I consider a larger single with a kicker and the weight is higher anyway unless I disregard security. I found that I can go all the way to a 200 and be lighter than the twins by 60 Lbs. Lastly, economy is paramount. I talked to someone once that would lift a motor and cruise on one at a time when a leisurely pace is OK. And go on two when speed is important. ...Thoughts? So what do you think would net me the best MPG? Two other points. One is that the boat will be pretty light by today's standards. Secondly, though I am a highly 'technical' person, I cannot fix a 'broken' motor in the middle of the ocean. But I could in all probability deal with a multitude of lesser problems. I do plan to carry a portable tank with an 'emergency' fuel supply. So I probably over think this, but I want to make good sensible choices as this will be much of my retirement enjoyment. ...Both the build and the use. Thanks in advance for any additional advice
OldGuy
