Re: Two fiberglass questions
A couple of things about using Chopped Strand Mat and Epoxy;
Traditionally CSM is not used with epoxy. The binder that is used to hold the fiberglass strands together in to a uniform cloth is not compatible with epoxy resin. CSM was originally developed for use with polyester resins to provide a random pattern in the mat for better adheasion and waterproofing. CSM is also used as a finish layer and as a way of conforming fiberglass into complex shapes and tight corners. CSM used alone is generally weaker than woven roving or cloth, so it is usually used along with a woven fiberglass product to provide strength. (this is the accepted thinking)
HOWEVER- I have been told that the binder in CSM IS compatible with epoxy and it can be used with it. So, I recommend that you verify with the vender or manufacturer of your particular CSM that it can be used with epoxy. It is my understanding that modern CSM binders are made to work with both resins but there are manufacturers that still make it the old way. It is best to check.
Personally I see no reason to use CSM with epoxy given that the advantages of using CSM are not needed when using epoxy resin. The only benefit I can see is that it is easier to get CSM to conform in to corners and weird shapes. Epoxy is stronger, it bonds better and it is far more watertite than polyester. So the benefits of CSM are not really needed. I generally recommend using a fiberglass cloth (weaved fiberglass, not woven roving) with epoxy resin. If you get print-through of the cloth weave on the surface you can use an epoxy based fairing filler to cover it before you paint. (because you cant use gelcoat over epoxy, you have to paint) But that is another debatable topic.
