i am working on a 1985 johnson 15 hp with manual start and tiller handle. i can crank it up and run it around the lake. then i go back to the dock, i turn it off, and it won't re-crank with a warm engine. bad coil, right?
i checked the resistances on the two coils. the primary winding resistances are 0.3 ohms and 0.4 ohms. the manual says that they are outside of the normal range; they should be about 0.1 ohms. the secondary winding resistances are within the normal range at 256 and 273 ohms.
now for my question: if the previous owner mounted the coils with hardware store washers on both sides of the coils, could they be poorly grounded? should i replace the coils, or should i remove the washers? does it even matter?
thanks in advance for your help,
john.
p.s.- i don't have access to a neon tester or a DVA meter at the moment, and compression is 112 on both cylinders.
john.
