two motors one tank
ralphl
main tank ,thru bulb, to fuel filter..filter/seperator thru bulb to each motor. That the best way ???
sschefer
Re: two motors one tank
The best way is with a tank with dual pickups. There is a real strong chance of fuel starvation and lean out if you try to run them both at the same time off a single pickup. My JetCraft has a dual pickup tank so I can run a kicker motor and the main at the same time if I want. If you do a search on dual engine installations or kicker motor installations you'll find the same warnings that I'm giving you.
ralphl
where can you find a dual pickup gas tank??
