Hi, 1992 Johnson 150hp VJ150EXENC My buddy's lower unit would not come off even welded up a slide hammer apparatus and it only laughed at me. Cut through the water pump and shaft (with much difficulty) with a sawzall and about 10 blades and dropped the lower unit. Am rigging up a puller arrangement for the end of the shaft, not sure now much heat the shaft will take at the crank end. There is about 1" of exposed driveshaft up top to heat. Anyway my question is: can I seperate the driveshaft just under the bearing housing assembly or does the whole 2 piece shaft have to come out as a unit and then be seperated? Thanks, Ken
