Hello all. I recently picked up a 1985 Bayliner with a AQ225D 5.0 Liter motor and a Volvo 280 outdrive. I checked the gear case oil and it seemed almost like it should but with just a bit of discoloration. I changed the oil and also put 5 psi in the gear case (which reminds me - the Clymer manual says to use 10-30 or 10-40 for the outdrive?). It lost pressure at about 1 pound every 3 minutes. I then sprayed the lower unit with soapy water and found that there was a slight air leak in the shift cover seal (not the gasket). I took out the four bolts but was not able to take the cover off. My Clymer manual just says to take the bolts out and remove the cover. Is there something else that I must do? Or should I just lightly tap on it with a block of wood and hammer to break the gasket loose? <br /> I then took the boat down to the ramp and put the boat in the water without taking it off of the trailer. As tempted as I was to go for a spin, I didn't want to suck any water into the gear case. I merely wanted to start the motor and check to see how it ran and also to check the outdrive. Everything seemed great. But when I took the boat out of the water, the exhaust bellows seemed to be leaking quite a bit of water out but I have not been able as of yet to find where it is coming from. The exhaust bellows seems about brand new. I changed the U-Joint bellows - so I know it is not leaking. Now, I have read on this forum that you can actually run your boat without the exhaust bellows without leaking water into the bilge. But if there is a hole or a leak in my exhaust bellows, will this cause damage? So, the two questions are about getting the shift cover off and also about the exhaust bellows. I appreciate your time.
