Two questions - what tach to use and just got huge commercial battery
WA-Newb
Tinkering with a few things on my boat and I am getting to the point where I need to have a tach for adjustments etc.
I have an old dwell / tach for autos...I am pretty sure this won't work but if anyone knows a way I am all ears.
I also have an auto tach that I got for a couple bucks but have never really looked at it since buying it (planned on putting it in old chevy truck).
I do not have any extra money to throw around so everything I need to do has to be as "ghetto" (cheap) as possible..lol
Sorry for the term but until I get this motor running decently every dollar bill spent is money down the drain.
Once I have it running decent then I can start putting a little money into her.
Anyway to adjust the timing, carbs...whatever else that I may need to do I am reading I need a Tach.
I don't even know how to hook one up yet but the first thing is figuring out what to buy / look for.
The motor is a 1968 Evinrude Starflite 100hp...has a power pack and electronic ignition (I don't know answers to points distributors etc....still learning)
So first question...
What is the cheapest way to use a tach on this motor...can be mounted or test kit...whichever.
Next question...
The boat needed a battery when I got it and I have been using my old chevy trucks battery...but I just found a huge commercial battery that I bought for $20...it appears to be out of a tractor or heavy piece of equipment. shows full charge and is 12 volt.
Can I use this type of battery for this outboard (or any outboard)?
Thank you.
Silvertip
Re: Two questions - what tach to use and just got huge commercial battery
Auto tachometers and tachometers for a two stroke magneto ignition are different in how they count engine revs. Your outboard counts pulses from the charging system. This is typically six pulses/revolution. The auto tach is generally set up to read "ignition" pulses from either a 4, 6, or 8 cylinder engine. A four banger produces 2 pulses per engine rev, a six cylinder does 3 and an 8 cylinder does 4 pulses per rev. So there is the issue -- setting the tach for a six cylinder engine (3 pulses) would cause the tach to read 1/2 the actually rpm on your boat. That is IF the tach can recognize the differences in the pulse waveforms. A 12 volt battery is a 12 volt battery. It can be the size of match book or the size of a dump truck. Your engine won't care.
WA-Newb
Thank you for the reply...I am having some bad problems now with my motor after "fixing" some wires and installing that new battery so I guess a Tach is least of my worries...sigh :(
I am reading here and there that some power packs don't have tach outputs either...since I cannot sind my power pack model anywhere I don't know if I can even hook up a tach or not...yet another sigh...lol
Thanks again thouhg..I will revisit your reply when (or if) I get my motor running again.
NYBo
The tach feed will be from the stator, not the power packs.
