Re: Two questions...
Should I just buy a whole carb rebuild kit while i'm doing that? I assume it's mostly gaskets that come with the carb rebuild kit. I CAN take it in to a shop, which will get it done correctly, but that will cost around 400 bucks, the shop says. Also, they said I need a new water pump because I told them the boat has been sitting for 7 years. But the boat had a full runthrough of new parts when they took it out of the water for the last time, I installed a new impeller, and the waterpump sucks water up through the engine fine. Any thoughts?<br /><br />And as far as trim goes, I have always thought, and here is my novice side showing through) that you were supposed to have the engine fully trimmed down as far as it could go. Should I play with the trim to find out a perfect spot for it? Even if it's not all the way down?
