Re: Two Strokes versus Four strokes
"1. Eventually you will get water in the fuel, either by your own fault or from a marina."<br /><br />I hate to break it to you buddy, but if you're getting water in your fuel, you're going to have problems with any outboard.<br /><br />Hasn't this "independent repair facility" ever heard of fuel/water seperators? All of my outboards have them, whether it's a 2-stroke or 4-stroke.<br /><br />
"They have already had to replace several heads with valves damaged by a healthy slug of water."<br /><br />That's odd. Pistons are usually the first things damaged by water ingestion. And 2-strokes have always been more susceptible to engine damage from water ingestion. BTW, water isn't really meant to be burned in any outboard.
<br /><br />
"2. In the very sad event you should sink your boat the 4 stroke is toast. With a two stroke, you can get it running again pretty easy."<br /><br />Are you serious? You're actually considering what type of outboard to buy based on which one will handle sinking better?<br /><br />I have bigger things to worry about if my boat sinks...like how many prayers I can say in my remaining 15 minutes of life as I tread ice water. BTW, don't you believe in insurance? <br /><br />
"They also thought that 4 stroke motors were way over priced."<br /><br />Over-priced? Don't you mean more expensive?<br /><br />I suppose in comparison to a KIA or Daewoo, a Toyota or Ford would be "over-priced" too?<br /><br />You get what you pay for. Usually fuel injection, better warranty, better economy, more pleasure (less smoke and noise), and IMO better overall durability, reliability, life span, maintenance, and performance. Lets not forget resale.<br /><br />
"I do too and am worried about putting a very expensive complex machine in a very abusive environment like the salt water marsh of South Louisiana."<br /><br />Salt water shows no mercy...2-stroke or 4-stroke. However, my 4-strokes have no carburetor linkages to corrode, and they come standard with fresh water flushes and anodes on the lower unit, transom bracket, and inside the engine block.<br /><br />IMO, there's only one advantage to 2-strokes, and that's weight on smaller boats.<br /><br />Your shop sounds very incompetent and misinformed to me.
