Re: Two wire trim to three wire trim
here is a harness I made from oval relays rather than the square ones but shape does not matter. As long as they are 5 pin they will work.
The red wires are power to the relays from the battery. The black wires are grounds. The purple wires are power from the relays to the tilt motor and the orange wires are signal from the tilt switch at the dashboard.
These relays are default to ground so when you energize one relay it send power down one wire to the motor while the other wire from the motor is grounded. The process is reversed when you energize the other relay.
On these relays:
E is power in from battery.
C and F are grounds.
A is power to the motor
D is signal in from dash.
The relay is market inside so you know which terminal is which.
Square relays use numbers like 85.
It is really simple but if you feel overwhelmed, as a friend who is good with electricity to help. It is really no more difficult than home wiring.
