Im looking to but epoxy for the floor of my 14' aluminum Lund and I was wondering what kind I use and if I can get it from home depot /lowes
if i am already covering it with carpet/vinyl do i need to paint it also? and does lowes/hd sell just epoxy?NOTE:*** If you use the Lowes or HD POLY resin you need to know a couple of things. 1.) It is WAXED. 2.) You need to use Fiberglass Mat with it. Without the mat it will dry very brittle and crack which will allow water intrusion into the plywood. The mat will keep this from happening. Since it is waxed, you will need to put additional coats of resin/mat on before it completely drys OR if it drys you will have to sand it using 60 grit paper to remove the wax to allow the next layer to BOND to the previous one. IF you use Epoxy you should know that it has NO UV protection and the Sun will eventually cause it to break down and it will also crack and peel. Paint it and the problem goes away.
