I have a 1996 Volvo DP-S with the Sx-C upper unit. I am replacing the U-joint assembly (see here). The drive shaft taper does not fit the Gimbal bearing (Shaft is about 3mm smaller in diameter than the inner ring of the gimbal bearing.) Any ideas about what's going on? Is this a manufacturing mistake? the u-joint assembly is an aftermarket made by glmmarine.com.
Thanks, AJ
Thanks, AJ
