I am getting water in the boat coming in from the drive shaft hole. I had this problem about 5 years ago and it was the U joint bellows. The only local shop available to me repaired it. I have since learned from other experiences that this shop can do some less than stellar work. I won't go into that, but suffice to say, I do all my own repair work now. I'm wanting to confirm the bellows is indeed split, or could it possibly be coming loose on one end. I found a video where someone discovered this on their's and ending up being able to simply reinstall the end that was working loose. Is there a way to inspect the bellows without having to remove the drive or bell housing? Thank you.
