jesse_boston
- Joined
- Aug 2, 2020
- 78
At idle, with the outdrive all the way down and steering straight, I can hear a slight knock. It almost sounds like the noise an old car engine I used to have made when it had spun a bearing, but much quieter. Above 800 or 900 RPM it settles out, no more knock.
But, if I turn hard to port or starboard, I can definitely hear it again, at any RPM.
I'm pretty sure this is the u-joints. How much noise is normal?
I could try to get an audio recording of it next time I have the engine running...
Am I risking catastrophic damage if I run it this way for the next few trips out, if I don't get into it when turning?
If a joint blows, will I be looking at transom repair, new gimbal housing, etc etc, or just a tow?
I will rebuild the u-joints this winter, would like to avoid doing it on a good boating day if I can wait.
Alternator: Mine is shot, battery worked its way down to 12.3 from 12.6 in a 5 hours of boating... not bad with the tunes going and the fridge running.
Is there a reason I should stay with a 3-wire alternator, instead of switching to 1-wire? Amazon can have a 1-wire 110 amp DB electrical alternator to me tomorrow, 3-wire end of the week if I'm lucky, next week if I'm not.
This is a 1995 5.7 mercruiser alpha 1 carb with a mechanical fuel pump, thunderbolt 4 ignition.
