Merc has a green Gimbal bearing and U joint grease. I've used the Penzoil red synthetic EP grease for 15 yrs, and my Gimbal brg. and disassembled U joints are as good as new. New U joints are sold as 'permanently lubed' with a plug to block the zerk hole. But I always install the zerk and flush the air from the cross passages, then add more until the end caps move, and I squeeze them back on to bleed the excess. This takes at nearly a full pump stroke on the grease gun. Far more than the mfg. added. Caution: if you ever add grease to an assembled U joint, do it carefully and with very little. It won't take much, if any, and if you force it you will blow the seals from their grooves, and have to disassemble them to reseat.
