Re: U-joint yoke removal from tp gearcase
Ted, which transmission do you have? You say 280, but also mention DP-C2.
Give this a read;
The A and later transmissions will use the integral bearing box/clamping collar.
It is all one piece similar to this (seq # 12).
The 270/280 style uses a steel BB (also seq #12 here) and separate aluminum clamping collar (seq # 35).
Be sure to use heat (to help with corrosion) on the main gear case housing when removing the four bolts.
Once the four bolts are out, we should be able to remove the entire BB and main drive gear out forward from the gear case.
We then loosen the aft-most cap screw from the male yoke in order to pull the universal joint assembly from the main drive gear.
The 270/280/285/275 etc is shim control for the BB rolling torque. If the seal surface washer is replaced, the rolling torque value must be re-set.
The A transmission and later will use a crush sleeve rolling torque control.
You'll want to use the correct re-assembly procedure for the transmission model.
For V-8 power, you may want to remove the gear from the BB and look at the bearing condition.
Many of the V-8 transmissions with some time on them, will be in need of main drive gear bearing replacement.
Ted, if you have gotten this far and the yoke does not want to come out of the gear, you'll want to use mild force on it. Might be a small bur or a twist in the splines. Try a brass punch but with light blows.
There should be nothing keeping it from coming out.
